When i install elen 12c touchpad driver my touchpad does’t work. how to solve it kindly guide me
The screenshot shows youre installing everything except elan…
Yeah, this screenshot shows that I didn’t install the Elan driver, but my touchpad doesn’t work. When I install all the drivers except the Elan driver, my touchpad works, but some functions don’t. Can you help?
you haven’t told us what device you’re using and what touchpad you actually have
I have Acer C720 (Peppy) and I used windows 10
there is no problem to solve here. Peppy came with both Elan and Cypress touchpad models. It’s also an older model that doesn’t support automatic detection of the trackpad type, so you have to install only the correct driver for your touchpad. You have a Cypress Touchpad, so install only that driver.
The Cypress Touchpad driver function is not working properly. For example, the single-click function sometimes doesn’t respond to touch, but it works fine when I click the touchpad button.
that’s an issue with the Cypress touchpad/driver then. It’s known to have issues / perform worse than the Elan pad. Not much can be done about it.
I discovered that my Chromebook’s touchpad touch works well when it’s plugged in, but it stops working when I disconnect it from the charger. Can you guide me on what to do?
keep the charger plugged in?
