Hi
I would like to raise an issue . After I installed the driver, my audio still not working. Any advice please. Thanks .
My device: Asus C425T
Board Name: Leona
Purchase audio : Coolstar SST (AVS)Audio
Thanks,
Hi
Board Name: Leona
Thanks,
double click it and tell us the reason for the exclamation mark
is says
This device cannot start. (Code 10)
{License Violation}
The system has detected tampering with your registered product type. This is a violation of your software license. Tampering with product type is not permitted.
then you haven’t activated your license, follow the directions in the readme / in the chrultrabook docs
should i re-install the driver again?
you loaded the signed license into the driver as per the instructions? and then rebooted?
Ohh apologies i forgot to load the signed license . it’s working now.
Thank you for the support.
