I’ve had no issues at all with this install except the USB-C ports don’t work. This has a Kaby Lake processor but I tried the Tiger Lake fix below and it didn’t work. Any other ideas?
Fixing USB C on TigerLake and AlderLake
Distros that use dracut for initramfs, such as Fedora, have an issue which prevents the cros_ec_typec kernel driver from loading correctly. You can fix it with the following steps.
- Create a file called
chromebook_typec.conffile in/etc/dracut.conf.d/ - Paste the following contents into the file:
omit_drivers+=" intel_pmc_mux "
- Rebuild your initramfs with
sudo dracut --force.
