Hello! I have been using this device on Windows 10 and 11 for years without any issue. After my exam session, I started using again my active pen, but now I keep having an issue. Pressure is detected on the screen, and it writes on onenote when the pen is 3mm away from the screen. I’ve never had this problem in the past, is there some way I can control the pressure sensitivity of the device? I will attach a photo to show you the issue. I can also confirm this behavior seeing touches when holding the pen 2/3mm away from the screen.
