No wifi on Pixelbook 2017 after installation of Ubuntu 25.10
I just got my Pixelbook 2017 (Eve) running with Ubuntu 25.10.
Using a USB-C dongle I can connect to Ethernet, but Network Manager doesn’t show my wireless adapter.
Below is the output of lshw. Any help would be appreciated!
pixelbook
    description: Convertible
    product: Eve
    vendor: Google
    version: 1.0
    serial: 8719G03U8L
    width: 64 bits
    capabilities: smbios-3.0.0 dmi-3.0.0 smp vsyscall32
    configuration: boot=normal chassis=convertible family=Google_Eve
  *-core
       description: Motherboard
       product: Eve
       vendor: Google
       physical id: 0
       version: 1.0
       serial: QCM650-00981-080D87400249
     *-firmware
          description: BIOS
          vendor: coreboot
          physical id: 0
          version: MrChromebox-2509.1
          date: 10/13/2025
          capacity: 16MiB
          capabilities: pci pcmcia upgrade bootselect acpi
     *-cpu
          description: CPU
          product: Intel(R) Core(TM) i5-7Y57 CPU @ 1.20GHz
          vendor: Intel Corp.
          physical id: 4
          bus info: cpu@0
          version: 6.142.9
          slot: CPU0
          capacity: 3300MHz
          width: 64 bits
          clock: 100MHz
          capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb pti ssbd ibrs ibpb stibp tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp vnmi md_clear flush_l1d arch_capabilities cpufreq
          configuration: cores=2 enabledcores=2 microcode=246 threads=4
        *-cache:0
             description: L1 cache
             physical id: 6
             slot: CACHE1
             capacity: 64KiB
             capabilities: internal instruction
             configuration: level=1
        *-cache:1
             description: L2 cache
             physical id: 7
             slot: CACHE2
             capacity: 512KiB
             capabilities: internal unified
             configuration: level=2
        *-cache:2
             description: L3 cache
             physical id: 8
             slot: CACHE3
             capacity: 4MiB
             configuration: level=3
     *-cache
          physical id: 5
          slot: CACHE1
          capacity: 64KiB
          capabilities: internal data
     *-memory
          description: System Memory
          physical id: 9
          slot: System board or motherboard
        *-bank:0
             description: LPDDR3 Synchronous 1867 MHz (0.5 ns)
             product: K4E6E304EB-EGCF
             vendor: Samsung
             physical id: 0
             serial: 55000000
             slot: Channel-0-DIMM-0
             width: 64 bits
             clock: 1867MHz (0.5ns)
        *-bank:1
             vendor: Samsung
             physical id: 1
             serial: 55000000
             slot: Channel-1-DIMM-0
             width: 64 bits
     *-pci
          description: Host bridge
          product: Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 02
          width: 32 bits
          clock: 33MHz
          configuration: driver=skl_uncore
          resources: irq:0
        *-display
             description: VGA compatible controller
             product: HD Graphics 615
             physical id: 2
             bus info: pci@0000:00:02.0
             logical name: /dev/fb0
             version: 02
             width: 64 bits
             clock: 33MHz
             capabilities: pciexpress msi pm vga_controller bus_master cap_list fb
             configuration: depth=32 latency=0 resolution=1800,1200
             resources: memory:cf000000-cfffffff memory:d0000000-dfffffff ioport:ffc0(size=64) memory:c0000-dffff
        *-generic:0
             description: Signal processing controller
             product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
             physical id: 4
             bus info: pci@0000:00:04.0
             version: 02
             width: 64 bits
             clock: 33MHz
             capabilities: msi pm bus_master cap_list
             configuration: driver=proc_thermal latency=0
             resources: irq:16 memory:ceed8000-ceedffff
        *-usb
             description: USB controller
             product: Sunrise Point-LP USB 3.0 xHCI Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 21
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:122 memory:ceef0000-ceefffff
           *-usbhost:0
                product: xHCI Host Controller
                vendor: Linux 6.17.0-5-generic xhci-hcd
                physical id: 0
                bus info: usb@1
                logical name: usb1
                version: 6.17
                capabilities: usb-2.00
                configuration: driver=hub slots=12 speed=480Mbit/s
              *-usb:0
                   description: Video
                   product: WebCamera
                   vendor: Generic
                   physical id: 2
                   bus info: usb@1:2
                   version: 0.06
                   serial: LOE65001063010A8470052BAI06BF12000
                   configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
              *-usb:1
                   description: Bluetooth wireless interface
                   product: Bluetooth wireless interface
                   vendor: Intel Corp.
                   physical id: 3
                   bus info: usb@1:3
                   version: 0.03
                   capabilities: bluetooth usb-2.00
                   configuration: driver=btusb maxpower=100mA speed=12Mbit/s
              *-usb:2
                   description: USB hub
                   product: USB2.0 Hub
                   vendor: VIA Labs, Inc.
                   physical id: 5
                   bus info: usb@1:5
                   version: 0.c4
                   serial: 000000000
                   capabilities: usb-2.10
                   configuration: driver=hub slots=5 speed=480Mbit/s
                 *-usb UNCLAIMED
                      description: Generic USB device
                      product: Anker USB-C Hub Device
                      vendor: Anker
                      physical id: 5
                      bus info: usb@1:5.5
                      version: 0.01
                      serial: 0000000000000001
                      capabilities: usb-2.01
                      configuration: maxpower=100mA speed=480Mbit/s
           *-usbhost:1
                physical id: 1
                bus info: usb@2
                logical name: usb2
                version: 6.17
                capabilities: usb-3.00
                configuration: driver=hub slots=6 speed=5000Mbit/s
              *-usb
                   product: USB3.0 Hub
                   physical id: 2
                   bus info: usb@2:2
                   version: 0.c4
                   serial: 000000000
                   capabilities: usb-3.20
                   configuration: driver=hub slots=4 speed=5000Mbit/s
                 *-usb
                      description: Communication device
                      product: AX88179A
                      vendor: ASIX
                      physical id: 3
                      bus info: usb@2:2.3
                      version: 2.00
                      serial: 009C1178
                      configuration: driver=cdc_ncm maxpower=184mA speed=5000Mbit/s
        *-generic:1
             product: Sunrise Point-LP Thermal subsystem
             physical id: 14.2
             bus info: pci@0000:00:14.2
             version: 21
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=intel_pch_thermal latency=0
             resources: irq:18 memory:ceecf000-ceecffff
        *-generic:2
             product: Sunrise Point-LP Serial IO I2C Controller #0
             physical id: 15
             bus info: pci@0000:00:15.0
             version: 21
             width: 64 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list
             configuration: driver=intel-lpss latency=0
             resources: irq:16 memory:ceece000-ceecefff
        *-generic:3
             product: Sunrise Point-LP Serial IO I2C Controller #1
             physical id: 15.1
             bus info: pci@0000:00:15.1
             version: 21
             width: 64 bits
             clock: 33MHz
             resources: irq:17 memory:ceecd000-ceecdfff
        *-generic:4
             product: Sunrise Point-LP Serial IO I2C Controller #2
             physical id: 15.2
             bus info: pci@0000:00:15.2
             version: 21
             width: 64 bits
             clock: 33MHz
             resources: irq:18 memory:ceecc000-ceeccfff
        *-generic:5
             product: Sunrise Point-LP Serial IO UART Controller #2
             physical id: 19
             bus info: pci@0000:00:19.0
             version: 21
             width: 64 bits
             clock: 33MHz
             resources: irq:32 memory:fe030000-fe030fff memory:ceeca000-ceecafff
        *-generic:6
             product: Sunrise Point-LP Serial IO I2C Controller #4
             physical id: 19.2
             bus info: pci@0000:00:19.2
             version: 21
             width: 64 bits
             clock: 33MHz
             resources: irq:34 memory:ceec9000-ceec9fff
        *-pci
             description: PCI bridge
             product: Sunrise Point-LP PCI Express Root Port #1
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: f1
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:121 ioport:2000(size=4096) memory:cef00000-ceffffff ioport:27f000000(size=2097152)
        *-generic:7
             product: Sunrise Point-LP Serial IO UART Controller #0
             physical id: 1e
             bus info: pci@0000:00:1e.0
             version: 21
             width: 64 bits
             clock: 33MHz
             resources: irq:20 memory:ceec8000-ceec8fff memory:ceec7000-ceec7fff
        *-generic:8
             product: Sunrise Point-LP Serial IO SPI Controller #0
             physical id: 1e.2
             bus info: pci@0000:00:1e.2
             version: 21
             width: 64 bits
             clock: 33MHz
             resources: irq:22 memory:ceec6000-ceec6fff
        *-generic:9
             description: MMC Host
             product: Intel Corporation
             physical id: 1e.4
             bus info: pci@0000:00:1e.4
             logical name: mmc0
             version: 21
             width: 64 bits
             clock: 33MHz
             configuration: driver=sdhci-pci latency=0
             resources: irq:21 memory:ceec5000-ceec5fff
           *-device
                description: SD/MMC Device
                product: DURM4R
                vendor: Unknown (21)
                physical id: 1
                bus info: mmc@0:0001
                date: 06/2018
                serial: 2646193194
                capabilities: mmc
              *-interface:0
                   physical id: 1
                   logical name: /dev/mmcblk0rpmb
              *-interface:1
                   physical id: 2
                   capabilities: gpt-1.00 partitioned partitioned:gpt
                   configuration: guid=578bf23f-24e9-4213-b2e8-dbf827c34822 logicalsectorsize=512 sectorsize=512
                 *-volume:0 UNCLAIMED
                      description: Windows FAT volume
                      vendor: mkfs.fat
                      physical id: 1
                      version: FAT32
                      serial: 2e23-2778
                      capacity: 1074MiB
                      capabilities: boot fat initialized
                      configuration: FATs=2 filesystem=fat
                 *-volume:1
                      description: EXT4 volume
                      vendor: Linux
                      physical id: 2
                      logical name: /dev/mmcblk0p2
                      logical name: /
                      version: 1.0
                      serial: 89a214eb-a4cf-4d4d-a3ce-f655d2bf3b1c
                      capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
                      configuration: created=2025-10-12 18:16:19 filesystem=ext4 lastmountpoint=/ modified=2025-10-18 15:18:24 mount.fstype=ext4 mount.options=rw,relatime mounted=2025-10-18 15:18:26 state=mounted
        *-isa
             description: ISA bridge
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 21
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master
             configuration: latency=0
           *-pnp00:00
                product: PnP device PNP0c02
                physical id: 0
                capabilities: pnp
                configuration: driver=system
           *-pnp00:01
                physical id: 1
                capabilities: pnp
           *-pnp00:02
                product: PnP device PNP0103
                physical id: 2
                capabilities: pnp
           *-pnp00:03
                physical id: 3
                capabilities: pnp
           *-pnp00:04
                product: PnP device PNP0b00
                physical id: 4
                capabilities: pnp
                configuration: driver=rtc_cmos
           *-pnp00:05
                physical id: 5
                capabilities: pnp
           *-pnp00:06
                physical id: 6
                capabilities: pnp
           *-pnp00:07
                product: PnP device PNP0303
                physical id: 7
                capabilities: pnp
                configuration: driver=i8042 kbd
           *-input:0
                product: Intel Virtual Buttons
                physical id: 8
                logical name: input15
                logical name: /dev/input/event9
                capabilities: platform
           *-input:1
                product: Intel Virtual Switches
                physical id: 9
                logical name: input16
                logical name: /dev/input/event10
        *-memory UNCLAIMED
             description: Memory controller
             product: Sunrise Point-LP PMC
             physical id: 1f.2
             bus info: pci@0000:00:1f.2
             version: 21
             width: 32 bits
             clock: 33MHz (30.3ns)
             capabilities: bus_master
             resources: memory:ceed4000-ceed7fff
        *-multimedia
             description: Multimedia audio controller
             product: Sunrise Point-LP HD Audio
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 21
             width: 64 bits
             clock: 33MHz
             configuration: driver=snd_soc_avs latency=64
             resources: irq:128 memory:ceed0000-ceed3fff memory:ceee0000-ceeeffff
        *-serial
             description: SMBus
             product: Sunrise Point-LP SMBus
             physical id: 1f.4
             bus info: pci@0000:00:1f.4
             version: 21
             width: 64 bits
             clock: 33MHz
             configuration: driver=i801_smbus latency=0
             resources: irq:16 memory:ceec3000-ceec30ff ioport:efa0(size=32)
        *-generic:10
             description: Non-VGA unclassified device
             physical id: 1f.5
             bus info: pci@0000:00:1f.5
             version: 21
             width: 32 bits
             clock: 33MHz
             configuration: driver=intel-spi latency=0
             resources: irq:0 memory:fe010000-fe010fff
  *-sound:0
       description: PROBE
       physical id: 1
       logical name: card0
       logical name: /dev/snd/comprC0D0
       logical name: /dev/snd/controlC0
  *-sound:1
       description: avsrt5514
       physical id: 2
       logical name: card1
       logical name: /dev/snd/controlC1
       logical name: /dev/snd/pcmC1D1c
  *-sound:2
       description: avsmax98927
       physical id: 3
       logical name: card2
       logical name: /dev/snd/controlC2
       logical name: /dev/snd/pcmC2D1p
  *-sound:3
       description: avsrt5663
       physical id: 4
       logical name: card3
       logical name: /dev/snd/controlC3
       logical name: /dev/snd/pcmC3D1c
       logical name: /dev/snd/pcmC3D1p
  *-input:0
       product: Lid Switch
       physical id: 5
       logical name: input0
       logical name: /dev/input/event0
  *-input:1
       product: Power Button
       physical id: 6
  *-input:2
       product: WCOM50C1:00 2D1F:5143 UNKNOWN
       physical id: 7
       logical name: input10
       logical name: /dev/input/event4
       capabilities: i2c
  *-input:3
       product: WCOM50C1:00 2D1F:5143 Stylus
       physical id: 8
       logical name: input11
       logical name: /dev/input/event5
       logical name: /dev/input/mouse1
       capabilities: i2c
  *-input:4
       physical id: 9
       logical name: input12
       logical name: /dev/input/event6
       logical name: /dev/input/mouse2
       capabilities: i2c
  *-input:5
       product: WCOM50C1:00 2D1F:5143 Mouse
       physical id: a
       logical name: input13
       logical name: /dev/input/event7
       logical name: /dev/input/js0
       logical name: /dev/input/mouse3
       capabilities: i2c
  *-input:6
       product: ACPI0C50:00 18D1:5028
       physical id: b
       logical name: input14
       logical name: /dev/input/event8
       logical name: /dev/input/mouse4
       capabilities: i2c
  *-input:7
       product: Tablet Mode Switch
       physical id: c
       logical name: input17
       logical name: /dev/input/event11
  *-input:8
       product: avs_rt5663 Headset Jack
       physical id: d
       logical name: input18
       logical name: /dev/input/event12
  *-input:9
       product: keyd virtual keyboard
       physical id: e
       logical name: input19
       logical name: /dev/input/event13
       logical name: input19::capslock
       logical name: input19::compose
       logical name: input19::kana
       logical name: input19::misc
       logical name: input19::mute
       logical name: input19::numlock
       logical name: input19::scrolllock
       logical name: input19::sleep
       logical name: input19::suspend
       capabilities: usb
  *-input:10
       product: AT Translated Set 2 keyboard
       physical id: f
       logical name: input2
       logical name: /dev/input/event2
       logical name: input2::capslock
       logical name: input2::numlock
       logical name: input2::scrolllock
       capabilities: i8042
  *-input:11
       product: keyd virtual pointer
       physical id: 10
       logical name: input20
       logical name: /dev/input/event14
       logical name: /dev/input/js1
       logical name: /dev/input/mouse5
       capabilities: usb
  *-input:12
       physical id: 11
       logical name: input9
       logical name: /dev/input/event3
       logical name: /dev/input/mouse0
       capabilities: i2c
  *-network
       description: Ethernet interface
       physical id: 12
       bus info: usb@2:2.3
       logical name: enxf8e43b9c1178
       serial: f8:e4:3b:9c:11:78
       capabilities: ethernet physical
       configuration: autonegotiation=off broadcast=yes driver=cdc_ncm driverversion=6.17.0-5-generic firmware=CDC NCM (NO ZLP) ip=192.168.36.192 link=yes multicast=yes port=twisted pair speed=1Gbit/s
Hello, same boat here. Try passing “pcie_aspm=off” to the kernel, that should fix it.
That worked, thanks! I’m curious why disabling ASPM helps.
Could you test whether cherry-picking commit l1k/linux@fc67a6f8a680 fixes the issue?
If it does, could you DM or e-mail me your real name and e-mail address so that I can add it to the Reported-by tag?
Thanks!
Happy to help, but this requires I build the kernel myself right? Never have done that before, if you can provide instructions on how to apply this commit and run with the updated kernel I’m happy to test.
Never mind, Adrià already tested the patch unsuccessfully. We’re trying to narrow the issue down further here:
However to give you credit for reporting this in a fix, I’d need your real name and e-mail address. So if you would like to be credited, please e-mail or DM it to me. Thanks.
This happened to mine on linux mint, suspending and coming back makes wifi work until I shut down
