No audio on Samsung V2 Plus
  • Device: Google Nautilus v1.0 sku0 (Samsung V2 Plus Chromebook)
  • OS: Linux Mint 22.3 XFCE
  • Firmware Version: MrChromebox-2512.2 (01/25/2026)
  • Internal storage type: eMMC
My laptop doesn’t have audio after installing linux mint 22.3 xfce.The audio script doesn’t work. Downgrading Linux version, installing Lubuntu latest version, nothing worked. I reverted back to ChromeOS and the audio functions like a champ, so it can’t be hardware issue. I’ve run out of idea. Here is the link to my debugging script: debug-logs-Nautilus-2026-03-28_22h05m - Google Drive
Model: Samsung Chromebook Plus V2 (Nautilus)
Ram: 4gb
Log of the audio script
Detecting platform
Detected Intel Kabylake
WARNING: Your device has max98357a and can cause permanent damage to your speakers if you set the volume too loud!
Type "I understand the risk of permanently damaging my speakers" in all caps to continue: I UNDERSTAND THE RISK OF PERMANENTLY DAMAGING MY SPEAKERs
Try again
Type "I understand the risk of permanently damaging my speakers" in all caps to continue: I UNDERSTAND THE RISK OF PERMANENTLY DAMAGING MY SPEAKERS
Enabling AVS driver
Installing UCM configuration
Cloning into '/tmp/alsa-ucm-conf-cros'...
remote: Enumerating objects: 117, done.
remote: Counting objects: 100% (117/117), done.
remote: Compressing objects: 100% (80/80), done.
remote: Total 117 (delta 35), reused 96 (delta 30), pack-reused 0 (from 0)
Receiving objects: 100% (117/117), 20.81 KiB | 887.00 KiB/s, done.
Resolving deltas: 100% (35/35), done.
Checking kernel config for 6.8.0-101-generic
Detecting codecs
Found max98357a
Found da7219
Kernel config check passed
Increasing alsa headroom (fixes instability)
Initializing sound card
alsa-lib parser.c:270:(parse_syntax_field) Incompatible syntax 7 in avs_max98357a.conf
alsa-lib main.c:1554:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -22
Found hardware: "avs_max98357a" "" "" "" ""
Hardware is initialized using a generic method
Found hardware: "hdaudioB0D2" "Intel Kabylake HDMI" "HDA:8086280b,80860101,00100000" "" ""
alsa-lib parser.c:270:(parse_syntax_field) Incompatible syntax 7 in avs_da7219.conf
alsa-lib main.c:1554:(snd_use_case_mgr_open) error: failed to import hw:2 use case configuration -22
Found hardware: "avs_da7219" "" "" "" ""
alsa-lib parser.c:270:(parse_syntax_field) Incompatible syntax 7 in avs_dmic.conf
alsa-lib main.c:1554:(snd_use_case_mgr_open) error: failed to import hw:3 use case configuration -22
Found hardware: "avs_dmic" "" "" "" ""
alsa-lib main.c:1554:(snd_use_case_mgr_open) error: failed to import hw:4 use case configuration -2
Found hardware: "avs_probe_mb" "" "" "" ""
Audio setup finished! Reboot to complete setup.
Warning: Your distro is not officially supported. Expect Issues.
Please try a supported distro first before opening an issue. See the README for a list of supported distros.
the script literally told you what the problem is / what the solution is.
Thank you for the reply. Sorry I wasn’t clarified it in the post. I am looking for a way to keep Linux Mint on my laptop because the distro is very easy to use. I am not very familiar with other distros. If there is really no other solution, I’ll do as you suggested. :+1:
plenty of distros are easy to use, Mint is no exception there.
your options are opening an issue on weirdtreething’s issue tracker for the script and hope he is able to help, or use a supported distro.
