i installed coreboot with the firmware util script, im trying to install linux from a usb and it detects it, lets me into grub, but of the three regular distros i tried, none get past grub, the fourth i tried is galliumos, and it barely worked, only showing a blank panel, mouse, and desktop. i am asking if anyone has had similar problems and solved it, or if anyone knows about the problem, at this point i just wanna get back into chromeos, but now it seems impossible unless theres an emergency image i can use to reflash my rom. any help would be greatly appreciated.
BOOKEM?
any 2024 linux release should work just fine - Ubuntu, Fedora, etc. be sure you are writing the ISO to USB as an image, as per the instructions.
Iām sorry there was a misidentification i actually have VILBOZ, i can only boot into kali, but i assume now that its probably a kernel thing or something, until i can boot a good gp desktop distro, im going to just stick with stock chromeos, thanks for the reply!
