My Latitude 5400 Chromebook laptop displays white text instead of green in the Developer Console, even though Developer Mode is enabled and ADB debugging is not. The laptop belongs to a company, but I own it. I need help installing Linux Mint and uninstalling ChromeOS using a 3.8GB USB drive.
1. Configuration
I’m using a 128GB SSD, 8GB RAM, a Celeron 4350U dual-core processor, a 3375mAh battery, and a touchscreen.
2. Errors occurred when I followed Gemini’s instructions.
When I pressed Ctrl+Alt+F2 and typed “chronos,” instead of “chronos” appearing, it asked me to re-enter my login name, and after 45 seconds, it reset itself. Even with Crosh, when I wrote the shell and code there, I encountered errors. When I successfully booted from my USB 3.8 drive, I turned the computer back on and a message appeared asking me to press the spacebar to re-verify the operating system. Then I pressed Ctrl+L and it reported an error.
