(not my image but same thing)
I ran the script and it said unsupported for arm devices is there any way I can get linux on my HP Chromebook 11MK G9 EE?
did you check the supported devices list?
Did you confirm that your Chroembook’s board name is DRAWLAT? Cuz that table doesn’t say “MK”
The MK variant has a MediaTek processor, which is an ARM processor.
ARM devices are not supported by the script (as indicated by the error message).
If you want to install Linux you should look at projects like posmarket.
But device support there is very spotty.
Your device seems to have postmarket os support: HP Chromebook 11MK G9 EE (google-esche) - postmarketOS Wiki
