Hi,
Has anyone figured out how to get the stylus input to rotate and the keyboard to disable in tablet mode under GNOME?
It seems that under Wayland this can only be fixed in Mutter, but that under Xorg there are some hacky ways to get styluses to use the wacom driver to then be able to force rotation.
Stylus works fine in default landscape rotation. Touchscreen input rotates but not stylus input.
I haven’t had any issues getting rotation to work on the current coreboot, however yes I agree the stylus acts a bit odd in tablet mode. Currently running KDE with Fedora, are Gnome distros better for tablet support on this, would you say?
Rotation works fine for everything except the stylus, which is still mapped to the original rotation no matter the position.
Does KDE automatically disable the keyboard in tablet mode?
I’m not really sure if GNOME is better, I installed it because I’ve been using it for several years. Everything seems to be good except for what I’ve mentioned.
Looks like same stylus oddness in both KDE and Gnome, then. Wonder if we need an extra driver? I read that wacom drivers are in the kernel by default, so other than updating input-wacom as mentioned on their sire, idk what we could do.
Any updates on this? I have the same issue with and Jinlon (fedora 40) device.
The proposed solution only works on x11, which breaks the touchscreen on myh device.
I am using a morphius device with 128gb NVMe drive and 8GB RAM. It is running Fedora 40, with both System76 COSMIC and KDE installed as DEs. I’ve mainly been on COSMIC for a while, as KDE may have had an issue during install and has had random freezes as of late. Could by my fault, could be the Fedora installer’s fault? Idk.
I’m on the most recent MrChromeBox firmware as of this writing, I believe: 2405, released 6/15/2024.
Fedora 40 is on the 6.9.4-200 kernel.
I haven’t been able to rotate the screen in COSMIC, but it rotates fine in KDE. The included stylus works perfectly fine regardless of orientation.
