Missing HWID (GIMBLE)
After reverting to ChromeOS on my GIMBLE (x360 14c-cd0), I get a warning that “A factory error has been detected”. I believe this is because of a missing/mismatched HWID, but I don’t have my original HWID to fix it. What can I do?
At this point I have zero sympathy for anyone who fails to back up and keep safe their stock firmware. The best you can do now is find another valid HWID for GIMBLE and set yours to that.
The script should’ve prompted you to create a backup of your stock firmware on a USB. That file should contain the original HWID…
Unless you lost the file you should probably be fine.
