MacOS Monterey on NAUTILUS?
  • Device: NAUTILUS
  • Platform: Intel KabyLake
  • OS: Arch → Monterey
  • Firmware Type: MrChromebox
  • Firmware Version: MrChromebox-2603.2
  • Internal storage type: 32GB eMMC
OpenCore 1.0.7 - OC: Driver OpenRuntime.efi at 0 cannot be loaded - Invalid Parameter!
  1. Install OpenCore 1.0.7
  2. Place the following kexts in this order:
    Lilu
    WhateverGreen
    VoodooPS2
  3. Boot
Should have began booting OpenCore (Not MacOS Yet)
Thanks for any help!
a cursory search or the forum here would turn up the solution quickly
Thank you, I did not look in depth enough.
