Summary of the Issue: Hello! Can MrChromebox-2609.0 and subsequent versions add a smaller control valve to the keyboard lighting? At present, the minimum adjustment is only 20% brightness, and I think the keyboard lighting at 20% is still too bright. Can I have a 15% adjustment or a 10% adjustment? Thank you!
this only controls the backlight level at boot - anything after that is up to the OS driver. I’m not sure there’s much value in adding more options for what is essentially a proof-of-life feature.
also, the post subject has nothing to do with the question asked. A better one would be:
Request: lower keyboard backlight adjustment steps in fw setup menu
