Already reported this in the discord, but putting it here for a more permanent record.
Basically, the GPU isn’t clocking over 200mhz unless you set it manually.
I haven’t tested additional distros, but I’m on Arch running Gnome.
Someone suggested I use CoreCtrl to set performance, but setting fixed high performance crashes the laptop.
Manually setting clocks to max out at 1150 is the current solution I’m running with.
This is for the C13 Yoga, yes?
I’ve only tested Fedora 39 Cinnamon here so far on this. I’m not on the discord but I’m here on the forum- what are you using to record the GPU clock issues? Radeontop?
I haven’t updated my coreboot in a bit, due to the trackpoint being enabled on my older build, as imho the C13 Yoga trackpoint is superior to a trackpad experience:
# dmidecode 3.5
Getting SMBIOS data from sysfs.
SMBIOS 3.0.0 present.
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
Vendor: coreboot
Version: MrChromebox-4.21.1-3-g233da37753d-dirty
Release Date: 11/24/2023
ROM Size: 16 MB
Characteristics:
PCI is supported
PC Card (PCMCIA) is supported
BIOS is upgradeable
Selectable boot is supported
ACPI is supported
Targeted content distribution is supported
BIOS Revision: 4.21
Firmware Revision: 0.0
But I also haven’t had any video playback or Risk of Rain Returns issues on this machine.
Also currently running openSUSE but I can throw Fedora or another distro back on here to do further testing if you would like.
