Whenever I try to install a new Linux distro, it just doesn’t work with my track pad and I am not able to move it unless I use a external mouse.
sounds rough
I have a Asus ck1405cka, is this perhaps the reason?
it should work OOTB under Linux. make sure the trackpad type is set to auto in UEFI settings
I’m on the RW_Legacy option. Is this normal for with this install?
RWL is always a crapshoot, because you’re still using the stock Google firmware. RWL is just a bootloader - there are no config options, no NVRAM, etc
pastebin your dmesg log after a fresh boot and let’s see what’s up
Where do I find that btw?
sudo dmesg > file.txt or whatever you want to name the file
cat file.txt |termbin.com 9999
Once you get the output give us the link.
Or you can do the same thing but instead of using termbin you can paste the output to a pastebin and give us the link.. Same concept
