Line-out only works with TRRS cable
Dear humanity,
I have a BUGZZY board (Samsung Chromebook 2 360) running Arch Linux. This device has a line-out. This line-out only works when connected to a TRRS cable . My JBL Tune 760NC headphones use a TRRS cable, so that is no issue.
Only when connecting to - for example - an amplifier (via RCA → cinch adapter) I can’t get any sound because the adapter doesn’t work with a TRRS cable and my laptop won’t recognize the 3.5mm TRS/TRS cable. When using the same cable with my smartphone, everything works as expected.
Under ChromeOS, it did recognize the TRS cable.
So:
  • When connecting a TRS cable to my BUGZZY Chromebook, the Chromebook won’t detect it.
  • A TRRS cable is detected, but can’t be used in multiple situations.
Can you run alsactl monitor and check the output when you plug/unplug both types of cables.
*Plugging in the TRRS cable*
node hw:0, #66 (0,0,0,Headphone Jack,0) VALUE
node hw:0, #67 (0,0,0,Headset Mic Jack,0) VALUE
node hw:0, #61 (2,0,0,Headphone Volume,0) VALUE
*Unplugging the TRRS cable*
*Plugging in the TRS cable*
node hw:0, #68 (0,0,0,Line Out Jack,0) VALUE
*Unplugging the TRS cable*
Interesting indeed, because this indicates that it is recognized by the system, but I can’t select it (tested in pavucontrol, alsamixer, KDE Plasma settings)
I’ve never seen a device with a “Line Out Jack” before.
Well, here you have one… Under ChromeOS it was also called ‘Line Out’. The output signal is also at line-out level.
Tempering with HDAJackretask does nothing (I’m only able to ‘Install boot overide’ (does nothing), ‘Apply now’ just crashes the whole application.)
Output of aplay -l?
> aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sofda7219max983 [sof-da7219max98360a], device 0: Speakers (*) []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: sofda7219max983 [sof-da7219max98360a], device 1: Headset (*) []
  Subdevices: 1/1
card 0: sofda7219max983 [sof-da7219max98360a], device 2: HDMI1 (*) []
  Subdevices: 1/1
card 0: sofda7219max983 [sof-da7219max98360a], device 3: HDMI2 (*) []
  Subdevices: 1/1
card 0: sofda7219max983 [sof-da7219max98360a], device 4: HDMI3 (*) []
  Subdevices: 1/1
Note: the only “HDMI” found on the device is via an USB-C → HDMI cable…
Try running the script again
I have run the script twice (once with and once without the TRS cable plugged in) and now it works! Thank you very much for your help @WeirdTreeThing !
