Device: MITHRAX (ASUS Chromebook Flip CX34 / CX3401FBA)
OS: ChromeOS (Stock) — flashing externally via Ubuntu Linux live environment (flashrom)
Firmware Type: Stock (attempting to flash MrChromebox UEFI Full ROM)
Firmware Version: Stock (unable to run script; Esc + Refresh + Power fails to enter Recovery/Developer Mode, and CCD is locked)
Internal storage type: NVMe
Unable to flash or read the onboard Winbond W25Q256JV_M (WSON-8) BIOS chip in-circuit using a CH341A Pro programmer, green 2x4 adapter, and WSON-8 pogo pin probe due to 3.3V power rail conflicts and USB dropouts (LIBUSB_ERROR_NO_DEVICE and LIBUSB_TRANSFER_TIMED_OUT). Because Esc + Refresh + Power will not trigger Recovery Mode (even with the battery disconnected) and CCD is in its default Locked state, external ISP flashing is my only option.
Attempt 1 (All 8 pins connected, board unpowered): Probed the Winbond chip with battery and AC unplugged. The CH341A’s 3.3V regulator gets overloaded trying to back-feed the motherboard’s 3.3V_SPI standby plane, immediately crashing the programmer (LIBUSB_ERROR_NO_DEVICE).
Attempt 2 (Pin 8/VCC isolated, board unpowered): Taped off Pin 8 on the probe. flashrom -p ch341a_spi successfully detects the Winbond chip (Found Winbond flash chip “W25Q256JV_M”) via phantom power from the SPI data lines, but attempting to read (–ifd -i bios -r stock_bios_backup.rom) immediately fails at Reading ich descriptor… with LIBUSB_TRANSFER_TIMED_OUT as the unpowered chip browns out.
Attempt 3 (Pin 8 isolated + internal Chromebook battery connected): Reconnected the internal battery so the motherboard could power the 3.3V rail natively while the CH341A only handled data + GND on the Winbond chip. Results in an immediate LIBUSB_ERROR_NO_DEVICE crash.
Attempt 4 (External 3.3V injected into Pin 8 via ESP32, board unpowered): Isolated Pin 8 from the CH341A and wired an ESP32’s 3V3 output to Pin 8 on the pogo probe with common GND tied to the CH341A while probing the Winbond chip. Still fails to read/communicate, likely due to voltage sag across the motherboard’s power plane or 5V logic clashes from the unmodified CH341A data lines.
The Winbond W25Q256JV_M flash chip should remain stably powered at 3.3V in-circuit without overloading the programmer or waking the PCH/EC, allowing flashrom to complete a clean read (-r) of the stock bios region, disable software write protection (–wp-disable), and write (-w) the MITHRAX UEFI Full ROM without libusb disconnects or transfer timeouts.
