Its $240 was going to use it for content consumption and coding
Is this the correct one? had i3-1215u and a fingerprint reader but idk if it is due to TAEKO having 2 models
How much ram does this have?
I bought a officially refurbished osiris ($300) which has a i5-1240P processor that blasts that cpu (I had a laptop with that cpu, I was not too impressed with its performance.)
Do note osiris does not have as much battery life due to a better cpu (about 3-4 hours on power saving mode)
That is also a lenovo chromebook, and lenovo designs are known to - deteriorate over time. I personally wouldn’t recommend it, but if your budget doesnt permit more than its not too bad
Was looking at the Osiris but from Acer, Asus? It’s out of stock and 8gb of ram
Yes, the osiris from acer.
Ram isn’t everything. Pagefile/zram/swap can help with that
If you’re planning to run windows, just turn up the page file (See the “committed” section)
Yeah got it I’ll just wait for it to go back in stock or something like that
There is a mithrax I think CX5501FE for $350 but idk
My C13 Yoga from 2021 is still rock solid- perhaps this is because of the aluminum chassi?
It’s also a Thinkpad
The flex 5 is plastic/aluminum will probably use it folded like once ngl
Dont know, but you can definitely ask in the discord server and youll see what people think about lenovo
