hello i got this laptop but i se now that i realy dont like chrome os and wounder if i can install windows on this one? here is a link to full spec on it to : https://psref.lenovo.com/Detail/IP_5_Chrome_16IAU7?M=82V9000LMX
does this mean i can because i have been looking true here and are still not 100% sure
what part of the documentation is unclear?
you need to ignore the make/model of your device, find your ChromeOS board name, then look in the supported devices list for it and see what the status is
ok thx buddy then it is what i was thinking
hi again i went true the tutorial and trying to install windows but i can find the internal storage for some reason, been searching true to find a good way to fix it
do you have any good pointers?
what do you mean by this?
when trying to install windows, then windows cant find the ssd so i cant install it
Hi,
I encounter the same issue and wonder if there is any solution to it.
Tried 23h2 with rst driver and none of the 4 worked.
24h2 shows install driver to show hardware.
Thank you
Found the issue, default SSD is trashy and won’t be recognized.
Replaced with a nvme 1th from amazon and installed 23h2 without any issue at all.
The one I used is 2280 the longer ones, but I assume 2242/2230 ones should work right.
Should definitely help, note that sata m.2 ones won’t work, must be key m / nvme.
ahh nice thx buddy
