Hey guys,
Successfully installed Windows 11 on a Lenovo Flex 5i. Everything works as it should minus the audio. So I bought the driver from Coolstar. Downloaded it, installed it. It still says no audio output. Bluetooth audio works fine. Now I am very tech savvy so what am I missing here?? Please assist.
If you attempted to install any intel/lenovo audio drivers you will need to delete those. I would recommend just re-installing the whole os if you did so.
Also make sure you installed all of the other drivers in coolstars guide, as well as followed the install instructions in coolstars audio installer. It should come with a readme file
I upgraded to Windows 11 and that fixed everything.
