Hello, I would like to report bug with emmc drive (first of all: I have tested from linux live emmc and its fine. i also tested ram with other live software). The windows 10/11 (tested tiny10, tiny11 and some older normal windows 10 build) have bluescreens from time to time (2-3 hours usually, sometimes right on boot). I tried the cmd command that should test all drivers and after that windows won’t turn on; there was bluescreen (too fast to read) but than I got windows loading error with file \windows\system\drivers\ntfs.sys with error 0xc0000221. I tried to repair it with help of chatgpt, that suggested checking emmc memory and ram (I did it and its fine). Than it said its probebly some low level driver issue bound to non official lenovo bios - mrchromebox. I can help with more tests, logs etc if needed.
there’s no issue with Geminilake devices using standard MS Win10/11 ISOs. You’re on your own using anything else.
Not an eMMc issue. Happened to me on my phaser360. Try using Official Windows iso’s and booting via them. Sometimes distros like tiny11 tiny 10 atomos and etc cause some issues in installation that the PC cant process.
