Landrid not showing with hp chromebook 15a-na0010ca when I look for it it shows up in supported devices then when I look for it to download the drivers it doesnt show up as well as when I type in the code word “Landrid” nothing shows up.
The list of what you need to install is the same as for all of the other Chromebooks with your chipset.
My one is the only one with landrid
LANDRID is not a chipset, LANDRID is the code name for your specific Chromebook.
Find out what processor your Chromebook uses, and pick literally any other Chromebook with the same processor from the list. The drivers are the same.
Same problem here
