Kano suzyqBoard is not found
  • Device: Kano
  • OS: ChromeOS
  • Firmware Type: stock
  • Firmware Version:
  • Internal storage type: NVMe
SuzqBoard doesn’t show up in ls /dev/ttyUSB*
I purchased the board from fyralabs. I’ve tried both USB c sides, flipped the board on each, plugging in via USB c to USB A. Tried on another Linux laptop, tried on a Linux mini pc and a windows desktop. The board doesn’t show up. Is it a dud? Anything else I can try to get it to register?
[What should have happened?]
You didn’t mention what type of USB-C cable you’re using. How exactly is it connected?
I’ve tried my pixel USB c cable, an anker USB c cable and a Google TV USB c to A cable. I’ve tried different ports, I’ve tried the dingle flipped I’ve tried the USB c female end connected, this way flipped and on multiple ports. I’ve tried all this on a Linux laptop, a windows desktop and a Linux server mini pc
This is the point where MrChromebox should weigh in; the SuzyQ debug board is a device developed by members of the Chultrabook project, and it differs significantly in appearance from the SuzyQ unit I use (the Chinese version, known as the SuzyQable Suzy-Q debug board).
I have no knowledge of any of the devices being discussed here.
On almost all boards, the CCD port is the left USB-C port. 99% sure it is on Kano.
If I plug the board in the top left and then a USB cable to my laptop I can see the device when I run /dev/ttyUSB*
What are the brand, CPU type, and specific model of the protected Chromebook device you intend to unlock? :face_with_monocle:
Sorry, the CR50 CCD communication port on my Asus CX54 Chromebook Plus is located on the right side.
giphy
It’s an Acer Chromebook Spin 714 (Kano)
Is it possible to install coreboot/UEFI Full ROM from Linux if I have the battery disconnected and run the útil script from a Linux terminal?
There is no Acer Chromebook Spin 714 model named “Kano”; the “Kano” motherboard is not an Acer product—“Kano” belongs to an Asus Chromebook.
Maybe it’s a typo. Kano is the Acer spin 714
I cannot determine the specific model of your Chromebook because I cannot see a clear photo of it. Furthermore, the device in your photo is not a Chromebook; Chromebook keyboard layouts do not feature a row of function keys (F-keys) at the top.
SuzyQable调试板,只为chromebook破解系统刷自定义UEFI而设计
It’s an Acer spin 714, kano. The image is of my laptop linked to the chromebook via suzyq board. It’s showing my laptop picking up the chromebook as ttyUSB
Is it possible to flash the firmware to coreboot from Linux with the battery disconnected?
Looking at the glue marks of the original label, it is a label that has been torn off, and the label is wrong. It’s weird, why can’t you take a complete keyboard photo? :joy:
new ones do.
it’s a typo, one anyone vaguely familiar with Chromebooks would recognize.
Chromebooks have disadvantages when the battery is turned off and flashing into UEFI, and the device unlocking is not completely incomplete. Subsequent UEFI/ The BIOS upgrade is at risk of bricking. If the battery is cut off, the protection and flashing into the UEFI are only the surface operation of the physical layer. If the operation is not appropriate, the static electricity of the human body will break through the internal circuit of the device. There are also many unknown and strange bugs in the subsequent use. CCD communication unlocking is a deep-level operation of the ChromeOS core, which is more thorough. more secure.
yes, but disabling via SuzyQ is the right way to do it
