It's another "audio not working" question. Linux Mint 22.2 on an Acer Spin 511
I understand this is a common request.
I followed the Chrultrabook instructions to replace the firmware on my Acer Chromebook Spin 511 and install Linux Mint 22.2. I also followed WeirdTreeThing’s instructions to install his audio fix, and it’s still not working.
The Audio settings show the output device as “Dummy Output” and no sound comes out. Weirdly, if I plug in headphones into the headphones jack, it suddenly displays my driver correctly and plays sound out of my speakers! This is the only way I can get it to make any sound out of the speakers, and there’s no way to make headphone audio work.
Any help would be greatly appreciated. Here is the debug file, as requested:
#!/usr/bin/env bash
printf 'Welcome.\nThis script will ask you for sudo password, which is necessary to extract required information.\n'
# Get current username before escalating permissions
user=$USER
# Get board name
board="$(cat /sys/class/dmi/id/product_name)"
# Get current date and time
date="$(date +"%Y-%m-%d_%Hh%Mm")"
# Specify where to store logs
logdir="debug-logs-$board-$date"
logarchive="debug-logs-$board-$date.tar.gz"
# Create directory to store logs
mkdir -p $logdir
cd $logdir
# Download cbmem and mark it as executable
wget https://mrchromebox.tech/files/util/cbmem.tar.gz &> /dev/null
tar -xf cbmem.tar.gz
rm cbmem.tar.gz
chmod +x cbmem
# Grab logs necessary for debugging audio
if [ ! -z '$(pgrep pulseaudio)' ]
then
	# Get logs from pipewire
	systemctl --user stop pipewire.{socket,service}
	systemctl --user stop pipewire-pulse.{socket,service}
	if [ -z "$(which spa-acp-tool)" ]
	then
		printf 'spa-acp-tool not found. On distros using apt, install pipewire-bin\n'
		touch no-spaacptool
	fi
	for card in $(grep '\[' /proc/asound/cards | awk '{print $1}')
	do
		echo "Pipewire card $card log:" >> audio-debug.log
		spa-acp-tool -c $card -vvvv info &>> audio-debug.log
	done
	systemctl --user start pipewire.service
	systemctl --user start pipewire-pulse.service
else
	# Get logs from pulseaudio
	systemctl --user stop pulseaudio.{socket,service}
	echo "Pulseaudio log:" >> audio-debug.log
	pulseaudio -v &>> audio-debug.log & sleep 5
	killall pulseaudio
	systemctl --user start pulseaudio.service
fi
# UCM logs
skip_ucm=0
if [ -z "$(which alsaucm)" ]
then
	printf 'alsaucm not found. Please install alsa-utils.\n'
	touch no-alsautils
	skip_ucm=1
fi
if [ -z "$(which strace)" ]
then
	printf 'strace not found. Please install strace.\n'
	touch no-strace
	skip_ucm=1
fi
if [ "$skip_ucm" = "0" ]
then
	do
		echo "Alsa card $card UCM log:" >> alsa-ucm.log
		strace alsaucm -c hw:$card reload &>> alsa-ucm.log
	done
fi
lsmod > loaded-modules.log
find /lib/firmware > firmware.log
# grab journal on systemd distros
if [ ! -z "$(which journalctl)" ]
then
	journalctl -b 0 > journal.log
fi
# grab a copy of /etc/os-release
cd /etc/os-release .
# Priviledge escalation [!!!]
	sudo su <<EOF
# Grab logs and redirect output to files instead of stdout
dmesg >> dmesg.log
if [ -z "$(which lspci)" ]
then
	printf 'lspci not found. Please install pciutils.\n'
	touch no-lspci
else
	lspci -vvvnn >> lspci.log
fi
if [ -z "$(which lsusb)" ]
then
	printf 'lsusb not found. Please install usbutils.\n'
	touch no-lsusb
else
	lsusb -v >> lsusb.log
fi
if [ -z "$(which dmidecode)" ]
then
	printf 'Dmidecode not found. Please install it.\n'
	touch no-dmidecode
else
	dmidecode >> dmidecode.log
fi
if [ -z "$(which libinput)" ]
then
	printf 'libinput not found. Please install libinput utils.\n'
	touch no-libinput
else
	libinput list-devices >> libinput.log
fi
## Copy ACPI tables
mkdir acpi
cp /sys/firmware/acpi/tables/DSDT ./acpi/
cp /sys/firmware/acpi/tables/SSDT* ./acpi/
# Grab coreboot logs
./cbmem -c > cbmem.log
# Set file permissions for regular user
chown -R $user:$user *
chmod -R 755 *
EOF
	echo "Error: Unable to gain root permission. Log archive will be incomplete!"
	touch no-root
# Remove cbmem binary
rm cbmem
# Pack logs into archive and remove temporary folder that stores them
cd ..
tar -caf "$logarchive" "$logdir"
rm -r "$logdir"
printf "Log collection done.\nPlease upload ${logarchive} for analysis.\n"
