Is there any way to get the audio drivers for free?
I live in a region where 10 dollars just for audio is a lot of money. Is there any other option besides buying a bluetooth speaker/USB audio card? i want to use the internal speakers.
use Linux.
I used to. I switched to windows because stupid school app i have to use that requires windows and doesnt work on anything else. thats why i jailbroke it in the first place, otherwise chromeOS is good enough.
well, your only option is coolstar’s paid drivers. If free drivers existed, coolstar wouldn’t have spent hundreds of hours (if not more) developing them
well i guess i’ll just get an usb to 3.5mm adapter. that’d do.
Install Linux then a VM with Windows on it and you should be good
