yes, with limitations:
- stock ChromeOS firmware ACPI is buggy
- suspend may or may not work
- without WP disabled, you’ll have the developer mode screen on every boot
- one can easily accidentally exit developer mode, causing you to lose the ability to boot any OS
it’s not recommended or supported. RW_LEGACY is for dual booting ChromeOS on non-EOL devices.
