Installing Linux on chrombook
  • Device: acer c733
  • OS: [trying to install linux]
  • Firmware Type: [Stock, RW_LEGACY, UEFI Full ROM]
I plug in my usb Flash drive I already used ruffus to flash in zorin is 18 I plug it in to my chrombook open it up and click esc then I go into the boot menu it dosent show up my usb Flash drive so will I have to use a another software or because I’m having trouble
update it didn’t work should I use a different software to download zorin
FAQ says to unplug/replug the USB on the main menu, wait 3s, then check boot menu again.
didn’t work
then try the other suggestions in the faq. there’s no secret formula
