Im using a chromebook 3100 2 and 1 and i keep getting the same errors
im using a chromebook 3100 2 and 1 and i keep getting the same errors when i type in cd; curl -LO mrchromebox.tech/firmware-util.sh && sudo bash firmware-util.sh. i get syntax error newar unexcptected token ’ newline’ and i dont know how to fix this
Greetings!
May we have you run through the instructions here to get your board name and architecture for this machine? This will help us help you troubleshoot.
Just checking in again. If you run through the instructions on that page to get your board name, we can help.
I’m running into the same issue as the OP: any tips for navigating?
it’s an Asus Chromebox CN60
I’m not sure why but clearly the curl command is downloading an HTML page and not the bash script. Try copying and pasting the link in your browser and seeing if it’s correct.
Not sure if it matters but is it the missing s in https ?
Hello! a lots been going on in my life so sorry for the late, LATE response, but sure! Its x86_64,Grabbiter,Intel Celeron.
It looks like you are downloading this webpage:
I imagine that the kodi script is deprecated,
replace setup-kodi.sh with firmware-util.sh
No worries! Glad you got back to the community haha.
Looks like that board has a CR50 battery setup for locking firmware. You’re unplugging the battery prior to running through the steps to flash the firmware correct?
If the issue is still happening with the battery unplugged, does the LOk option work? Also that O is the letter O and not the number 0 in case you’re running into that issue. That’s what I ran into when I first tried on my Morphius a while ago.
cd; curl -LOk mrchromebox.tech/firmware-util.sh && sudo bash firmware-util.sh
