Ah, sorry! Hopefully this is better.
After logging in as root in the terminal, I get to the ChromeOS Device Firmware Utility Script with:
cd; curl -LOfk https://mrchromeboxmrchromebox.tech/firmware-util.sh && sudo bash firmware-util.sh
I pick option 2, Install/update UEFI (full ROM) firmware, say yes to the warnings, no to the backup of the stock firmware.
Skipping backup - ensure you have a backup stored safely!
Download Full ROM firmware
(coreboot_edk2-parrot-mrchromebox_20260714.rom)
############ 100.0%
############ 100.0%
Persisting device HWID
VPD extracted from current firmware
Disabling software write-protect and clearing WP range
Installing Full ROM firmware (may take up to 90s)
Firmware flash failed; retrying once…
Firmware flash failed after retry.
Attempting to restore previous firmware from /tmp/bios.bin…
CRITICAL: Failed to restore previous firmware.
DO NOT REBOOT. Seek recovery help if the device will not boot.
Please report this issue and include /tmp/flashrom.log
(and session log /tmp/mrchromebox-20260805-154341.log)
Press [Enter] to view the flashrom log file, then space for the next page, q to quit
I press enter
=== attempt 1: writing coreboot_edk2-parrot-mrchromebox_20260714.rom ===
Wed Aug 5 15:59:25 PDT 2026
flashrom v0.9.9 : 87913db : Apr 06 2018 18:51:24 UTC on Linux 3.8.11 (x86_64)
Calibrating delat loop… OK
Coreboot table found at 0x7beddc00
The Flash Descriptor Security Override Strap-Pin is set. Restrictions implied by the FRAP and FREG registers are NOT in effect. Please note that Protected Range (PR) restrictions still apply.
Invalid entry specified: BIOS
FAILED
=== attempt 2: writing coreboot_edk2-parrot-mrchromebox_20260714.rom ===
Wed Aug 5 15:59:26 PDT 2026
FAILED
=== restore: writing /tmp/bios.bin ===
Wed Aug 5 15:59:27 PDT 2026
Calibrating delay loop… OK
FAILED
An error occured flashing the Full ROM firmware
Press [Enter] to return to the main menu.
Pressing space for the next page, nothing happens. I had to recreate it just now to get the info, but this happened every time.
