I need recommendations for an affordable tablet
Hello, I would like recommendations for an affordable tablet that is runs for under 250 on the used market. I already own a Lenovo Duet 5 and it runs great, only issue with it is that it does not support Custom Firmware due to the snapdragon. I would like to have a tablet that includes a keyboard just like the Duet 5 but I need x86 options, and still runs well with custom firmware. Does anyone have any suggestions?
You can install GNU/Linux without modifying the firmware. Not everything is supported though. See
  1. GitHub - hexdump0815/linux-mainline-on-arm-chromebooks: running linux mainline on arm chromebooks - for example: samsung xe303c12 and xe503c12 (snow and peach), acer c100, c101 and c201 (veyron speedy, minnie etc. and gru bob and kevin), medion s2013 and s2015 (veyron jaq, mighty etc.), acer cb5 311 (nyan big), lenovo n23, acer r13 (oak elm and hana), lenovo duet (kukui krane) and most probably many many more over time ...
  2. Lenovo IdeaPad Duet 5 (google-homestar) - postmarketOS Wiki
AFAIK, there is still no x86 Chrome tablet.
But many nice x86 convertibles are available. I personally use HPx360 14a (blooguard), and one of my friends has a Lenovo 500e 2nd gen (phaser360). Both work quite nicely (everything is supported in LMDE and Kubuntu 24.04), and have long battery life. The latter come with a stylus for the display.
SORAKA is a x86 Chromebook tablet.
Thanks so much for the reply. I will definitely look into installing pmOS on my device. I used to have an x86 Nautilus but sadly the device is not working anymore and settled for a Duet 5 as my main CB.
You should fully understand what works and what doesn’t work on postmarketOS on trogdor at the moment. Also the process to install postmarketOS is very manual.
If you’re perfectly happy with how your Duet 5 runs right now, why install a different OS that has less support?
If you can find one for a good price, I’d recommend the ThinkPad C13 Yoga (Morphius), I got mine with a Ryzen 5 3500C, 8gbs of RAM, 128gb SSD and a USI pen for $256 Canadian, so far it’s running Gentoo Linux really well all things considered. My only suggestion would be to try to get the highest possible config you can for a reasonable price, I would not recommend paying $700 bucks if you can, $256 is what I personally would consider a fair price for a C13 Yoga.
I know this is an old thread. But I recently went down this rabbit hole with the ARM Lenovo duet 3. I got it pretty cheap ($80) and even picked up the Suzzy Q with it. I wanted the camera to work so elected not to go with Postmarket. Google has made some interesting moves as of late and I no longer enjoy Chrome OS so I’m probably going to resell it.
I also found a Lenovo Duet 3i (Intel x86) version for equally good price and going to try running Fedora on it this weekend. Not sure why but Lenovo doesn’t typically sell this in the United States. I’ll keep you updated how it goes but seems like everything should work with a newer Kernel.
