i have purchase SOF intel audio driver and registered my driver, and driver has installed successfull and no error but there is no sound came out from speaker can i have solution for this
just info i have installed windows 11 64bit all driver is successfull installed but there is no sound on speaker
Firstly, I’m sorry that I jumped to the comment section without any solution.
But how did you manage to install W11 on Zyrex M432-2? Where’s the WP? Can you tell me how to Install it? I have an exact same model as you, and I want to install Linux in it.
Thank you.
you can disable the WP trough disconnecting battery method, and install the bios firmware. it works on me. But i also have the same problem, there is no sound from the speaker altough the driver is installed. And also the wifi driver not working on me too.
