HP G4 14 Chromebook, bios kip 09-06-2024, has issues can’t install OS. But in old bios 6-15-2024 is good. i think some setting in bios is Wrong
What you do mean “Can’t install”? What OS?
Baytrail Chromebooks (among others) had an issue with the initial 2408 release which caused Windows to fail to boot, but an update was pushed to correct that, so if that’s your problem then you just need to update.
