So, for a VERY long time I wanted to take my Chromebook 14 to the modern age to give it life.
Finally did! Looks very nice, used chromebox, and elected for flex to not change the hardware strain and use type factor.
Only one hickup. Touchpad is a no go on being recognized. I even found the driver from coolstar. But only exe’s work on windows, not Flex.
Any tech guru know a way to install/fix the built in touchpad?
External mice work. Even built in cellular (prob sd card slot too) works. Not a deal breaker to keep an extra mouse, just awkward. Thanks for any help, I’m assuming another command menu download or such. I just know nothing in general.
Thanks for the suggestion. Have a 4GB ram model. Was hoping to avoid any more robust OS’s, but noted. Chromebook fills what I need, ill see how needing external mouse sits with me for now. Much appreciated regardless.
I have the same issue. It happened sometime in 2026 May. Until that time the touchpad worked well under ChromeOS Flex. Since it does not work, even with the latest MtChromeBox firmware. However it works if I boot into ubuntu.
