Hp elite c1030 chromebook
SOF driver for HP c1030
audio/sound drivers is needed for his model i need to purchuse for and i dont know how anyone who can help
I’d ask if you’ve read the documentation but the answer seems obvious
problem is i cant find how to activate or purchise for ir
Go here
GitHub - WeirdTreeThing/chromebook-linux-audio: Script that enables audio support on many Chrome devices running various Linux distros read all of it
And
Officially Supported Distros
  1. Alpine Linux edge
  2. Arch Linux
  3. Debian Trixie
  4. Fedora 42
  5. OpenSUSE Tumbleweed
  6. Ubuntu 25.10
  7. Void Linux
Other Distros
Other distros will likely work but will require you to manually install packages. The script will print a list of any packages you may need to install. It is required to have a relatively modern distro (no old LTS releases) as those will be missing important fixes.
