HP Chromebox G4 (Gladios) not supported?
Hello, thank you very much for your reply.
I simply need to install Linux on an HP G4, but even after removing the battery from the motherboard, the write protection is still enabled.
I have only been able to install it with the dual boot option, but that doesn’t work for me; I need to completely replace Chrome OS.
I understand that suzyQ is necessary in this case, is that right?
If not, how can I remove the write protection on this computer?
I will send you a private message to see the trial version.
Thank you very much for your help.
yes
