Hp Chromebook 14 db003na Audio
I have ran the script and i had no audio. i ran the debugging script and installed the things that it said i needed. Im using a pretty fresh install of arch linux with minimal packages.
Here is the tar.gz the script says to upload.
Its possible you might just need to enable the audio device, depending on your desktop environment, audio server, etc. Does a sof device show up when you press f6 in alsamixer?
No i dont think this is what i get
Yeah, your issue is different than what I had
yes.there will show information like this;so what should I do then ?
If it’s amd stoney(a4-9120c cpu etc.) then you will need to use a custom kernel for sound GitHub - chrultrabook/stoney-kernel: Script to build the weird kernel needed on stoneyridge chromebooks you can download it already built on https://nightly.link/chrultrabook/stoney-kernel/workflows/build/main/stoney-kernel.zip
didnt it warn you about this when you ran the script?
