Image taken after reassembly
that’s, um, a lot of solder. Why did you solder the pads next to the ones labeled WP? Why did you disconnect the battery?
I’ve had the same issue with some HP boards (Drawlat mainly) where a jumper didn’t disable HWWP. I don’t know why it didn’t work but I ended up using a Suzy Q or programmer in those cases.
Battery was disconnected because typically that’s a step, I soldered the other 2 because just the hwwp ones worked
