Has anyone here gotten the HP Active Pen working on linux (Ubuntu 24.04) on Jinlon?
With a vanilla install, the “Tablet” section of gnome-settings shows no tablet, so I think it’s a matter of correctly detecting the hardware via libinput?
The screen works great as a touchscreen, just not as a tablet with the pen.
“not supported” means that if you have a problem and ur on Ubuntu then the people answering your question will say “Install something else”. If u have a problem with audio not working, WeirdTreeThing will not help u unless it’s on a “supported” distro.
Honestly, I just want to know if any distros support the screen behaving as a wacom tablet with a USI pen. If anyone has a working setup, please let me know which distro and setup scripts you’ve been using.
The pen gets detected on supported distros, but the input does not rotate with the screen, so it is unusable in landscape mode. I haven’t found any solution to this problem.
Using Fedora with KDE Plasma on most of my devices, or postmarketOS with Plasma Mobile on ARM64 devices I’m working on. Everything works as you would expect.
Please note that we don’t support X11 at all. It’s dead, please use Wayland instead.
For clarity and future searchers: The HP Active Pen G3 is NOT a USI stylus, and will NOT work on the Jinlon hardware. After replacing the Active Pen G3 with a HP USI Stylus, the system works perfectly.
The “HP Active Pen G3” is an AES2.0 stylus and thus will never work on the Jinlon hardware. I was mislead because I had assumed that the “HP EliteBook 1030” was identical hardware to the Jinlon “HP Elite Chromebook c1030”, which is incorrect, and they have different touch/tablet hardware as well as other changes.
I have purchased a USI Stylus the “HP Wireless Rechargable USI Stylus” and it works perfectly under ChromeOS and Ubuntu without additional drivers or modifications.
