I’m very new to all this stuff and have been trying to get my audio working for a while now. I’m on Fedora 42 on a HP 14-db0006no CAREENA board Chromebook and it (Apparently) has AMD StoneyRidge. I’ve tried doing the script multiple times but that changed nothing. The script said because I had AMD StoneyRidge I should use the prebuilt kernel from the source listed (Index of /stoneyridge-kernel/). I didn’t quite know what to do that that info but eventually downloaded all 4 .rpms and used sudo dnf install on all of them. After a reboot, though, nothing changed. Dummy audio is still the only thing there. If anyone can help I’d appreciate it a lot! Here is a pic of the script so you can see what it said ![]()
