Hello, I’m a bit confused about how to jailbreak an ASUS Chromebook CM34 Flip with a FROSTFLOW motherboard. Could I get some assistance?
Edit: I know I’m probably going to get replied with “RTFM” but I did and I’m still very confused
use a SuzyQ cable and follow the instructions to disable WP using it.
You can also bridge the jumper on the mainboard and then disable AP firmware verification as per the documentation.
IMO the SuzyQ cable is the better option as it gives you the ability to unbrick if needed
