I am using Fedora KDE, I want to go into fullscreen but the original fullscreen key and Ctrl + Shift + F doesn’t work either, please help. Thanks!
Plasma Search (hit the meta key) → type shortcuts → type fullscreen → click kwin → Hardcode whatever you’d like to be fullscreen, including the defaults that aren’t currently working
Also, try meta + Up arrow to see if that is a preset option. It might be one I reprogrammed, but it’s intuitive so it might be a default
This worked, thanks!
