Help me with bricked hp chromebook 11a g6 ee
I recently installed the full rom on my hp chromebook 11a g6 ee, everything was working correctly except for overheating in the device soI recently installed the full rom on my hp chromebook 11a g6 ee, everything was working correctly except for overheating in the device so I decided to reinstall the backup I had of the ROM, I used the same script with which I installed UEFI and apparently it was restored without errors, there was only a message saying I would have to reinstall the system from Google media creation, so I used the letter p to turn off the device, I left it off but connected to the charger while to the USB with the system, the thing is that when I finished and connected the USB I tried to turn on the device and it did nothing, it was just hot and the charging LED was on. I disconnected the battery and tried the method with the buttons mentioned in the mrchromebox wiki, but nothing happened, only the LED turned off. My biggest question is do I need some kind of programmer or something complicated to unbrick the device?
I ask because I am from Latin America and it is very difficult to get things like the suzyqable or programmers for the bios,I ask because I’m from Latin America and it’s very difficult to get things like the suzyqable or programmers for the BIOS. I tried connecting a USB whose LED lights up when reading its data, but it didn’t do anything. I should mention that when I connect the battery only the device heats up but the screen does not light up as in other cases I have read.
For now I can only say thank you for reading, if my English is weird it’s because I used the translator since I’m not very good with long texts.
Discharge the device: Keep the lid open, do not connect the charger.
Turn it on after a few days and you may get it turned on, worked with my G8 ee, both use the same board
