Hi! So I recently found my old chromebook from a few years back and I have just flashed the full ROM. When I went to install Arch Linux, I encountered errno 28. Now i’m trying to partition the drive but I have one question. Does the MrChromebox firmware script install to the mmc or is it installed to a chip on the main board?
Don’t worry, the firmware that the script installs is not installed in storage, so it is installed as if it were a “BIOS” update even though it is not a BIOS, so don’t worry if you want to format the disk
ok thank you!!
