- Device: Dell Chromebook 11 5190 2-in-1 (Nasher360/Coral)
- OS: Arch Linux, kernel 7.0.12-arch
- Firmware Version: MrChromebox-2603.2
- Internal storage type: eMMC
Basically when I plug my headphones in there is a pretty good chance anything which trys to play sound through them just hangs, including the speaker tester (front left, front right thing yk). Sometimes when I plug it in it works for a bit till I either use too much CPU or open an electron app (apologies if im just rambling, no clue if this is actual cause) then YouTube music for example just infinite loads, my speakers and bluetooth audio work flawless, just this headphone jack im really stumped on.
Plug in headphones
Listen to music
It hangs
It should play it i guess.
I attached the file from the debug script so you don’t have to read my bad explanation.
Also worth mentioning this has the max98357a (spooky)
Any help will be appreciated, feel free to call me a dumbass if I am one. Cheers.
https://files.catbox.moe/9ecosu.gz (its a tar.gz)
