GitHub will not let me do a git clone command
The function on my Chromebook do not work. I found a patch from GitHub and tried running it in the terminal GitHub ask for a username and password the same way it does for the audio patch. The thing is, I did the audio patch a couple days ago. So I can’t remember how I got the patch to go through as GitHub no longer allows you to put a username and password in. Can anybody help me out?
You’ve got a problem with github so why are you asking for help here? personally I would just download the repository as .zip with a browser.
