Hello! I looked through previous posts and never found an answer, so I’ll ask on a new post. Where is the jumper on the Gateway Chromebook 15/PASARA?
If someone could point it out on the board, that’d be great!
It is unknown whether Firmware WP is solved by jumper, so your best option is to use a SuzyQ cable (you can buy these off EBay)
