Flashrom gave a “couldn’t parse the descriptor” error when flashing a W25Q128.W winbond chip on a HP chromebook 14a G5. I used a GSC Debug Board (aka "Chromebook Debug Cable" / "SuzyQ", for Cr50 / Ti50) | eBay cable and Ubuntu latest. rw is off and wires are properly connected and detected. Any help is appreciated.
RTFM
and if you have issues, provide the full command line used and the full output.
from what limited info you provided, I’m guessing you tried to use --ifd -i bios or similar on an AMD Chromebook, which doesn’t have an IFD.
I think your right, it seems to be working, currently flashing. btw is there a way to close a post, like the way github does it?
nvm its not booting, is there a way to log the boot?
elcome to minicom 2.9
OPTIONS: I18n
Port /dev/ttyUSB0, 20:24:52
Press CTRL-A Z for help on special keys
[810.778614 WP 1]
[814.493492 power button pressed]
[814.525112 Recovery Requested]
[814.911727 AP UART on]
[814.938907 deferred_tpm_rst_isr]
[814.940017 AP on]
[814.940635 tpm_reset_request(0, 0)]
[814.941505 tpm_reset_now(0)]
[814.945953 tpm_init]
[814.948307 tpm_manufactured: manufactured]
[814.956485 tpm_reset_now: done]
[814.958293 CCD state: UARTAP+TX UARTEC+TX I2C SPI USBEC+TX]
[814.965396 tpm_rst_asserted]
[815.040210 deferred_tpm_rst_isr]
[815.041282 AP on]
[815.041908 tpm_reset_request(0, 0)]
[815.042732 tpm_reset_request: already scheduled]
[815.099517 PinWeaver: Loading Tree!]
[815.112491 Skipping commit]
[815.228202 Skipping commit]
[815.239868 Skipping commit]
read_tpm_nvmem: object at 0x1008 is smaller than 40
[815.253990 load_ec_hash error: 0x1203]
[815.254951 Skipping commit]
[815.268192 Skipping commit]
[815.280609 Skipping commit]
[815.383678 Skipping commit]
[815.536209 AC: -F]
[815.571498 Committing NVMEM changes.]
[815.758792 AC: R-]
[817.634590 power button pressed]
[817.747768 Recovery Requested]
[817.748455 tpm_rst_asserted]
[817.784252 AP UART off]
[817.786128 CCD state: UARTEC+TX I2C SPI USBEC+TX]
[818.261859 AP UART on]
[818.286579 deferred_tpm_rst_isr]
[818.287658 AP on]
[818.288280 tpm_reset_request(0, 0)]
[818.289127 tpm_reset_now(0)]
[818.293346 tpm_init]
[818.295696 tpm_manufactured: manufactured]
[818.304107 tpm_reset_now: done]
[818.305934 CCD state: UARTAP+TX UARTEC+TX I2C SPI USBEC+TX]
[818.313072 tpm_rst_asserted]
[818.387893 deferred_tpm_rst_isr]
[818.388992 AP on]
[818.389595 tpm_reset_request(0, 0)]
[818.390419 tpm_reset_request: already scheduled]
[818.447669 PinWeaver: Loading Tree!]
[818.463100 Skipping commit]
[821.305789 Committing NVMEM changes.]
Again I don’t see a command line showing us what you flashed and how you flashed it.
why do you continue to make us guess as to what you’re doing?
