Could someone point me in the right direction on which firmware file to download using the ch341a flasher?
I have read the documentation on the mrchromebox website but couldn’t find the exact files i need.
I have the chromebox 3 cn65 intel i7.
why do you need/want to flash with a ch341a? What are you trying to accomplish?
Something went wrong during following the tutorial on the website and therefore i need to flash it manually. Somehow it got bricked. But in the meantime i found the exact version.
Still don’t know if i will spend that time on it though.
Thank you for your hard work on making it all possible.
it’s takes all of 5 mins to reflash it, including disassembly and reassembly
Could you explain what i need to do exactly i want to give it a try.
use the ‘fizz’ firmware image for the CN65
