I’m in the process of learning how to flash my own firmware with SuzyQ cable. I’ve disconnected the battery, connected to the GSC console by using screen
to one of the USB TTY device, and successfully changed the ccd
state to open.
However, upon using flashrom
to actually interact with the flash chip (trying to read them), the operation fails to recognize the chip, thus failing to read from them:
Found Generic flash chip "unknown SPI chip (RDID)" (0 kB, SPI).
Read is not working on this chip. Aborting.
FAILED
Banshee uses Winbond W25Q256JVEM as its AP flash chip and it seems to be one of many devices supported by the raiden_debug_spi
programmer. However, the log suggests that it doesn’t get get recognized. The id in the log is full of 0x00
so this suggests that the fault is in the reading, not the matching.
I used @ChocolateLoverRaj ‘s GSC debug board v4.1.0, various flashrom
versions (Ubuntu 2304, NixOS’ flashrom
1.3, @WeirdTreeThing 's repo), and various USB-C cables, all with the same result.
I could try it with a WSON-8 probe, but I’m posting here first just in case someone had a similar experience and successfully solved it. Any suggestions?
Here is the log. Thank you in advance!
