Failed to extract firmware image for bobba
Sorry for low quality, I’m posting this at 12 am
I’ve been using this for a while now and no issues, other than this.
I’m trying to restore from recovery usb, I remade it multiple times and even tried different Linux distros
Dont use a recovery image unless you have to. If possible, recover without the usb and use the shellball rom.
There is no shell ball rom? I flashed it a while ago too and lost the backup. Plus I’ve used recovery usb tons of times before. What you said doesn’t solve my problem
there are no shellball ROMs provided by the script, that’s what the restore from recovery USB function is for
Any fixes? Still getting same issue
remake the recovery usb? Also make sure you select the right block device. In your screenshot it looksl ike you selected 2 when the correct one was probably 1
